2 blown waterpump gaskets in 3 months...
Old Nov 10, 2002 | 08:20 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Since August I have blown 2 waterpump gaskets. I'm not talking about the pump-to-block gaskets, but the one that seals the metal plate to the back of the pump. I had one start leaking in August. I replaced the gasket but it still leaked so I got a rebuilt pump from Schucks for around $17 and it worked great until just recently when it started leaking at that gasket also. What could have caused both gaskets to fail in such a short time or is the second gasket failure just a coincidence?
Old Nov 15, 2002 | 08:18 PM
StangKiller's Avatar
Not sure why the first pump leaked but the second one was probably because it was a $17 pump!!! You get what you pay for, get a good pump like a Stewart and you won't have anymore failures. I've had a Stewart pump for 8 years and it's still going strong!!!
Old Nov 15, 2002 | 11:27 PM
rezinn's Avatar
Could be two things: 1) bad luck 2) your coolant is old and acidic and is eating through the gaskets. Since you actually replaced the pump, I'd assume you flushed the coolant and didn't reuse it, so it's likely bad luck. FYI I use silicone on the back of the water pump, not a gasket. I've never had mine leak.
sheachopper
Jul 31, 2019 11:27 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Jonas Earl
Sep 27, 2015 07:39 AM
383backinblack
Sep 25, 2015 11:31 AM
KCG
Sep 23, 2015 09:05 AM
