Worried about cooling
Old Nov 12, 2002 | 12:43 PM
88ViperKiller's Avatar
Hey guys,
I'm dropping a 383 into my 1988 Firebird that originally had a V6...obviously I need a new radiator.
How far do I need to go to properly cool a 400HP/TQ 383 on the strip and occasional street. It wont be a daily driver, but it does need to keep cool while cruising.
I'm planning on a high performance aluminum water pump for weight and cooling efficiency, and I'll be sure to have a proper fan cooling the radiator. I am on a budget, so how far must I go with the new radiator? Would a 2 core aluminum radiator with plastic tanks be sufficient?
[Edit] Thought I'd add...my heards are aluminum,...which are better at dissipating heat and less prone to hot spots...
Old Nov 14, 2002 | 11:54 PM
Shagwell's Avatar
Car: projects.......
Mike Crew is running a 383 w/ stock radiator and a Flow Koller water pump. His car is running consistent 12.3 - 12.4's and he reports an occasional 195 beating it severly at the track and 175 in town on a 180 t-stat. The stock 2-row aluminum works great. Good Luck!
Old Nov 15, 2002 | 12:42 AM
Sweet, Shagwell...thanks a lot!
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
