Yippy Kiyay
Old Dec 21, 2002 | 10:01 AM
TransAm's Avatar
From: Somewhere in between Lynn, MA (home) and Lakeland, FL (school)
Yippy Kiyay
So i just replaced my heater core and upgraded my thermostat from 160* to 180*... after i buttoned everything down i pressure tested my system. All the connections were fine.... but there is deffinitely a small leak comming from the intake manifold. Looking straight at the engine, its the closer-left hand side, right next to the valve cover.
It seems like something i'm not gonna be able to fix without a major tear down.. anyone have a second opinion??
Old Dec 21, 2002 | 10:08 AM
1986redbird's Avatar
sounds like an intake manifold gasket let go, how much pressure did you put on the system ??, it shouldn't be that hard to replace the gasket (depending on what setup you have). might as well go ahead and upgrade the intake to a performance style while you have it off (if you don't already have one).
Old Dec 22, 2002 | 03:42 AM
TransAm's Avatar
Put it up to just under 16 PSI... where 16 PSI is the pressure my cap warrants. So pretty much. I was planning on brining a torque wrench to my intake and making sure that everything is buckeled down to the appropriate pressure.
Old Dec 22, 2002 | 06:09 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
You can try going through the whole sequence of bolts, dont do just one. Its like a leaking dam, you plug one whole with your finger and another will open. Worst case scenario, replace the intake gaskets.
Old Dec 22, 2002 | 07:43 AM
Andy Bush's Avatar
If the leak is from the manifold it can go down as well as up, so it might be worth checking the oil didn't get coolant in it.
Old Dec 22, 2002 | 11:31 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i would consider changing the intake manifold gasket...
RockinGTA89
Jul 25, 2005 07:10 PM
91 GTA Ramair2
17
Jan 5, 2004 05:24 PM
91 GTA Ramair2
Dec 28, 2003 11:27 AM
FAST RS
Jul 18, 2001 11:41 PM
branz28
Jan 1, 2001 01:54 PM
