electric fan
Old Jan 8, 2003 | 01:16 PM
68Beater's Avatar
electric fan
My fan fuse blows everytime that i put a new one in. This started very recently. I disconnected the relay to check it, but with the fan relay disconnected it still blows fuses. Has my fan gone south?
Old Jan 8, 2003 | 04:07 PM
MdFormula350's Avatar
does the fan move at all? maybe it froze up and blows the fuse, and if it moves it maybe drawing too much current and blowing it that way, or you have a short somewhere else..
Old Jan 9, 2003 | 08:32 AM
68Beater's Avatar
fan...
the fan does not move at all...
Old Jan 9, 2003 | 04:05 PM
Camar92's Avatar
Car: 1986 IROC-Z
Engine: Vortec 350 with mild cam
Transmission: 700r4 Mild build
Axle/Gears: Stock
Check the wires all the way up to the fuse block. Chances are the wire coating may have rubbed/burned/ came off and could be rubbing on a ground. If all your wires look good, its most likely what he said, your fan pulling too much current. Is your fanstruggling to spin freely, or is it just the motor that doesnt make it spin?
Old Jan 10, 2003 | 08:54 AM
68Beater's Avatar
The motor is not energizing or moving at all and so the fan is not moving in the slightest...
sheachopper
Jul 31, 2019 11:27 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
