ok, let's try again
Old Jan 9, 2003 | 03:02 PM
fakeshemp's Avatar
ok, let's try again
Sorry about the messed up posts. Let's try again. Here's the problem. I have a 92 RS with a TBI 305. Everything is pretty much stock. I pull out of the driveway and within two blocks the Temp gauge reads over 260. On a friend's advice I put in a new thermostat this morning. Pull out of the drive and it does it again. Any ideas about this? I'm thinking mabye it needs a new waterpump.
Old Jan 9, 2003 | 03:59 PM
Camar92's Avatar
Car: 1986 IROC-Z
Engine: Vortec 350 with mild cam
Transmission: 700r4 Mild build
Axle/Gears: Stock
The water pumps on our cars arnt very good, chances are the fins on the water pump corredoed off, or, you may have a clogged radiator, which can happen from corrision too. Check pressure on the hose. Hope its not serious!
Old Jan 10, 2003 | 01:24 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Ok, you've done 1 thing, so keep going.
1- check the hoses for pressure.
2- have radiator cap tested/replaced.
3- check for air or low coolant levels.
4- perform a radiator flush.
5- replace the tempature sending unit.
6- Remove the waterpump and check for corrosion.
7- make sure the fans are turning on.
Have fun and let us know what happens.
Old Jan 10, 2003 | 05:43 PM
fakeshemp's Avatar
I replaced the water pump today. Problem solved. Went ahead and flushed the system while I was at it. Now I can focus on all my other projects. Thanks for the advice!
Old Jan 11, 2003 | 11:38 AM
MdFormula350's Avatar
glad to hear you fixed the problem!!
