over-pressurized system?
Old Mar 1, 2003 | 09:21 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Is there something that could possibly cause the cooling system on my '91 RS to become over-pressurized? In the past few months I have blown almost every seal, gasket, hose, etc. in my cooling system. What gives?
Old Mar 1, 2003 | 11:30 PM
jeffs82z28's Avatar
Put a cooling system pressure tester on the radiator and run the motor, and check to see if the system pressurizes quickly.
If it is being pressurized, then I would do a leak down test on the individual cylinders to check for a blown head gasket/ cracked head/block, etc...
If you see bubbles in the radiator while doing the leakdown test, be ready to spend money.
Old Mar 2, 2003 | 01:35 PM
82camaro's Avatar
Car: 82 camaro SC
Radiator cap is supposed to release the pressure. Put a new cap on.
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
