Cooling Fan help please
Old Mar 9, 2003 | 03:47 PM
92RedRS's Avatar
Ok, so I saw a post answering this question a LONG time ago, and tried the search but can't find it. So bear with me on this. My cooling fan doesn't kick on anymore. I replaced the relay and the sensor and still nothing. I know the fan works cause it kicks on when I turn the AC on. I am hoping that it is a simple wiring problem... any help is greatly appreciated....
Old Mar 9, 2003 | 04:56 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
sounds like you have a break in the wire from the relay to the fan switch(you did replace the one in the pass side head between #6 & #8 exhaust ports, right?)
Old Mar 10, 2003 | 12:38 PM
Formula4Phil's Avatar
i have the same problem, i havent put a new sensor in yet, but i hope that is all it will need. will a thermal sensor from jegs or summit work, i'm using a 180degree thermostat and i want the fan to turn on around 170 or so
Old Mar 10, 2003 | 01:08 PM
i read the two stickies at the top, it seems that the problem could be a number of things. I will do more research under the hood, and post my results.
Old Mar 10, 2003 | 09:18 PM
MdFormula350's Avatar
yeah common problems are the coolant temp sensor and the fan switch.
my fan switch was burnt up and thats why my fan was always on when i started the car.. it took me a few minutes to test and narrow it down when i tested the other components in that circuit.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
