need help
Old Apr 30, 2003 | 05:18 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
need help
my car is running at 260 again cuz my fan will not go on. it was working fine and now its not i just changed the fuse or what ever is on teh fire wall driver side like 3 weeks ago cuz it wasnt going on and now its doing it again please help thanks
Old Apr 30, 2003 | 06:32 PM
camaroracer1's Avatar
Car: 1988 Iroc-Z
Engine: 5.7 TPI
Transmission: TH-350
Axle/Gears: 12bolt/4:10
Your fan switch could be broken, its located on the passenger side of the engine block or maybe the fan relay doesn't work? Are you running a 50/50 mix and make sure your air dam is in good shape. Also make sure your wires are all intact.
Old Apr 30, 2003 | 11:59 PM
jocww's Avatar
i just replaced my relay and the wires looked ok i dont know about the mixture i think its like 60 40
Old May 5, 2003 | 12:26 AM
jocww's Avatar
i dont see the thing i on the pass side.
hte relay which is on the drivers side i switched and it didnt do anything
