heater coil i think (pics)
Old May 18, 2003 | 12:11 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i'm having a coolant leak inside the car, i was cvacuming the car today and saw some fluid on the carpet right by the botom air ducts. so i felt it and smelt it to make sure its not ol and then realized its coolant. i started to take apart some of my interior apats to find the problem but this what i came to.
Old May 18, 2003 | 02:22 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Your correct..that is the heater core.From what you describe it is bad hence the leakijng and needs to be changed.Keep going till you get it out and put and new one in and you will be back in bussiness.Not hard at all.
Old May 18, 2003 | 02:44 PM
Engine: peanut LB9
thanks, it doesn't wanna seem to come out and what sizes are the hoses that go into it because when i do it i wanna repace thehose clkamps too. along with whatever hoses i can
Old May 19, 2003 | 07:47 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Should be 1/2" and 5/8" hoses that connect to it.
Old May 19, 2003 | 02:12 PM
Z383's Avatar
No it's 3/4 and 5/8 inch. Check to see if there's debris clogging the rad fins.
GM designed these cars to run hot for clean emmissions. the ECM won't turn the fans on until 225.. Jet performance will have a unit that will kick the fan on at 195.
Old May 19, 2003 | 08:22 PM
Engine: peanut LB9
your right its 5/8" and 3/4" of an inch i'm having problems when i go to put the new one in. it doesn't wanna fit with that piece on there(the plastic peice that holds it in place. WTF
Old May 20, 2003 | 09:03 PM
Engine: peanut LB9
its al fixed now, i bought a couple feetof hose of each, and i didn't know they where prebent hoses.
but it took me about 4 hours to do
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
rsrookie
Sep 5, 2015 07:08 PM
