Overheating in traffic
Old May 19, 2003 | 12:16 PM
92Formula305's Avatar
My '92 formula 305 is overheating when I slow down and get into traffic. On the hiway it is fine, running around 160-170. I noticed that the main fan never comes on, even during the code checking procedure. The only way I can keep my car from getting too hot is to turn on the A/C, and that sometimes isn't enough in Texas. Where is the relay located for the main fan? The wiring diagram doesn't show it's location. Thanks in advance.
Old May 19, 2003 | 11:49 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
has the water pump been replaced?
check for a whining noise. my old rs did this. it ran fine on the freeway, b/c there was plenty of air, but around town, i had to run the a/c to keep it cool (and keep the fan on)
after i replaced it, it was fine
Old May 20, 2003 | 07:48 AM
Well it hasn't been replaced since I have owned it.. about a year. It does make a slight mechanical whine, much like the sound a BMW 6cyl makes. I assumed it was the sound of the serpentine belt setup. But I know for a fact that the fan doesn't come on, so there's at least that problem, I just don't know which relay it is.
Old May 21, 2003 | 02:04 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
does yours have a dual fan setup or single?
does the a/c on cause the fan to run, or is it still off?
i wish i knew the site, but you can buy your cars factory service manual for about $60 i believe. i'll have to look over my notes from asep school to find it. if i do, i'll let you know
this book will have step by step of where and what to check, plus it will be invaluable for later repairs
Old May 21, 2003 | 02:25 PM
Well I've made some progress. It does have the dual fans. I jumped the relay and the fan came on so at least I know it works and the wires to it are decent. It must be the sender to turn it on, or possibly some of the fusible links that are in the circuit. If you find that source for the manual I'd really appreciate it. The A/C fan works as it is supposed to. Now...when retrieving codes are both fans supposed to be on?
Old May 22, 2003 | 03:12 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
another option is to use your own adjustable fan controller like one of these from Autozone.
Old May 22, 2003 | 11:32 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
www.helminc.com
hope that works,
they should have a factory service manual for your car
http://www.helminc.com
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
