AC out ? add power?
Old May 19, 2003 | 01:14 PM
~sweetP~'s Avatar
AC out ? add power?
if you take out the AC in your third gen can it increase the amount of power or horsepower that you may have after taking out the belt and everything. just wondering because its been wandering in my head as thought.
thanks
sweetp
Old May 23, 2003 | 01:10 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Taking the a/c out will reduce weight since you could remove the condenser, evaporator, compressor, lines, accumulator, etc. It won't increase engine power...
Old May 23, 2003 | 07:02 PM
MdFormula350's Avatar
i took my a/c off my car, it gave me a whole lot of room, and took some weight off.
i just bought an a/c delete pulley because i have a serpentine setup.
it sounds like u have a v-belt system if so u can just take off the v-belt and compressor and the rest of the a/c stuff.
Old May 25, 2003 | 07:14 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The A/C is pretty benign unless the compressor is operating. Translated it means shut it off during a run. It is nice to have room in the engine compartment though.
Old May 25, 2003 | 07:22 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Removing the A/C will reduce weight and not add any power to your car ONLY major discomfort in Hot & Humid weather.
Old May 25, 2003 | 07:47 AM
lockdude's Avatar
Every belt and every pulley takes power from your engine. One belt=5hp, or so. The difference is negligible, but if you can live without your a/c, then every bit helps. Some people even go as far as installing an electric water-pump to save hp.
Old May 25, 2003 | 08:09 AM
DJP87Z28's Avatar
On a Stock or near Stock engine its is not going to make a big difference if you have the A/C or not in the Horsepower numbers.
midge54
Dec 27, 2019 04:14 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
gta90
Sep 15, 2015 04:00 PM
sailtexas186548
Aug 24, 2015 10:11 PM
sreZ28
Aug 14, 2015 07:48 PM
