Overheating no mater what!
Old May 28, 2003 | 10:49 PM
mpitts77's Avatar
new thermostat...120 or 160..can't remember, new radiator cap, coolant flush, and i have the air dam. Why oh why will this thing not stay cool?. Gets almost up to redline..then it will drop down to about 240 then start climbing to the red. Any suggestions?
P.S. Fan is hard wired on as soon as the key is turned.
92RS
Old May 28, 2003 | 11:12 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Look into the radiator with the engine running to make sure the pump is working.
After that if the pump is good then you might have to check the radiator.
Old May 28, 2003 | 11:15 PM
mpitts77's Avatar
Yeah im waiting around to see if a friend still has the cooling system out of the thirdgen iroc they turned into a drag car. I hope so...FREEBIE!!! =O
Old May 29, 2003 | 02:38 PM
mpitts77's Avatar
Flushed the radiator this morning..chunked the thermo..got about 2 miles down the road...red line...pulled over..car sounds like it has marbles rolling around in it now =/ A suggestion to me was the car was running lean since the exhaust manifolds were white hot (really...they were white).
Should I try messing with the timeing? Are my valves shot?
Thanks,
Michael
92 RS
Old May 29, 2003 | 03:50 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
YES Check your timing and make sure that the firing order is right.
1-8-4-3-6-5-7-2
Kat
Old May 29, 2003 | 06:24 PM
350IROCconv's Avatar
Overheating
I have a 91 350 TPI which HAD the factory dual fans hooked up to a switch. My radiator tank blew out and when I replaced the radiator a ton of stuff was caught between the radiator and the condensor. Check to make sure you don't have anything there. Also I switched to the single large fan and leave it on all the time. Before in traffic it would creep up to 240 now it won't got over 160, the thermostat temp. Just some thoughts, stick with it you'll figure it out.
Oh if your timing is retarded the car will heat up more than normal so mabye check that. And make sure you have the stock airdam.
1988 Iroc-z Convt. W/ 1991 350TPI Drivetrain
FORSALE!!!! Please someone buy it I need the money.
Old May 29, 2003 | 08:20 PM
mpitts77's Avatar
well...the engine is fubared. Barley run..sounds like a couple of bent rods =/ BUT getting a already built 350 for 250 dollars =D Thank im gonna take the 305 out and see if it can be rebuilt just incase i need another one
Old Jun 5, 2003 | 10:08 PM
wilfred's Avatar
it sounds like a clogged radiator get it serviced thank me later.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
