Best Thermostat to pass CA smog
Old Jun 9, 2003 | 11:08 PM
tamonez's Avatar
Car: 88 Iroc
Transmission: 5 speed
I was having problems with my car running hot. I got a 160 stat and now it runs way cold. I just read somewhere that 160 will make my car produce higher emissions, is this true if so what would be the best for emission? should I stick with stock?
Thank you
Old Jun 10, 2003 | 05:16 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
stock 195 deg will be best.
Old Jun 10, 2003 | 12:38 PM
MdFormula350's Avatar
a 180 stat would be a good compromise between the both. thats what i use now, u still can let the car sit for awhile and warm up.
Old Jun 23, 2003 | 07:13 PM
T/A gets T&A's Avatar
Even though it's a PITA...I say use the stock 195 for the test, and switch to 180 afterwards.
Old Jun 24, 2003 | 11:18 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Nah, I pass CA emissions with a 180 t-stat. All you have to do is dump a bunch of fuel alcohol in the gas tank before you take it in to get smogged. Before I used alcohol I barely passed. Last time, with alcohol, I passed with flying colors. You can get a gallon of fuel alcohol at most hardware stores.
Old Jun 28, 2003 | 04:38 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
I passed SMOG with a 160 thermostat and the ZZ4 in the car with no EGR. Just made it look like it had EGR
sheachopper
Jul 31, 2019 11:27 AM
jaridjohn
Oct 5, 2015 07:01 AM
