Pressure Test
Old Jun 12, 2003 | 02:54 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Pressure Test
Hello all,
Have a question about the radiator pressure testing. When I put the pressure tester on the radiator, and give it 30 lbs of pressure. Will this test tell me if I am leaking coolant in head and intake gaskets? Do I want to test stone cold or warm. Any and all ideas will be greatly appreciated.
Brad
San Diego
Old Jun 25, 2003 | 08:40 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
if you have a leak in the intake you will see coolant squirt out real hard if its internal you will see white smoke on start up! because if you had a bad head gasket the coolant would force into the cylinded and burn off!
take it easy on the tester 30 though lbs seems a little much i could be wrong though i think i only went up to around 16ish maybe 20 max
angel2794
Sep 8, 2015 06:22 PM
mike_c
Aug 27, 2015 04:32 PM
92camaroJoe
Aug 13, 2015 06:07 AM
