running all water?
Old Jun 13, 2003 | 05:47 PM
StealthElephant's Avatar
Car: 87' Iroc
running all water?
is it bad to do that in the summer? does glycol act as a lubricant?
Old Jun 13, 2003 | 06:27 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
The main thing the cooling system needs is corrosion protection. Just add a couple of bottles of RedLine Water Wetter with distilled water and the cooling system will be fine.
Old Jun 13, 2003 | 06:35 PM
Car: 87' Iroc
does that combo help cooling compared to 50/50 mixture of h20/glycol?
thnx
Old Jun 13, 2003 | 08:41 PM
GKK's Avatar
GKK
Water absorbs heat faster than the 50/50 anti freeze mix but, water will have a lower boiling temperature and will freeze in the winter.
Antifreeze protects the different metals in the cooling system (radiator, waterpump, engine block) and raises the boiling temperature of the water and will not freeze in cold climates.
So yes, using distilled water with the redline water wetter will absorb heat more efficiently and give corrosion protection like the 50/50 mix but, only use it during the summer. Also, I've found that using the stock 195* thermostat gives the most consistant cooling temperatures.
Old Jun 14, 2003 | 07:42 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
thnx
The boiling point of the coolant is not affected much by the antifreeze but by the system pressure. For each pound of system pressure the boiling point of the coolant raises about 3 degrees. Antifreeze has more to do with corrosion and freeze protection than boiling. Most manufacturers I have talked with recommend no less than a 30% antifreeze/ 70% distilled water. Less than 30% glycol and you lose the ability to provide adequate freeze and corrosion protection. Antifreeze also acts as a wetting agent for the interior surfaces of the radiator allowing better thermal transfer. I don't know what the "wetter" concentrate costs but it will be probably cheaper just to change the standard mix since the water is actually the primary cooling medium.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
toronto formula
Nov 10, 2015 06:17 AM
lakeffect2
Aug 23, 2015 08:44 AM
Street Lethal
Aug 12, 2015 11:33 AM
