210* stat runs@240, 180* runs@180
Old Jun 25, 2003 | 12:29 AM
Charlo's Avatar
I hope you guys are willing to help me with my truck. I swapped a junkyard TBI454 into my K5. She has a massive quality 4core in her.
The junkyard motor came with a 195* stat and ran at about 240*. I replaced the stat with a new 195* and got the same results. I put a 180* in her and she runs at 180*. I suppose I should try a 195* stat but why would she act like this? Also what temp should I aim to maintain? Thanks
Charlo
Old Jun 25, 2003 | 08:31 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
you sure you ran the truck the same way? like you didnt drive on the highway when testing teh 180 stat right?
that is a wierd problem though.
Old Jun 25, 2003 | 08:58 PM
patrickm00's Avatar
not sure when the ECM would put things into closed loop mode, maybe it's like 190°, so you're not reaching it. this could affect things like fans, etc.
also, the temp gauges aren't very linear. are you measuring temp with a real gauge, or just on the dash?
Old Jun 26, 2003 | 12:09 AM
Charlo's Avatar
Only measuring temp from the dash.
The weirdest part was after first installing the 180* stat she ran between 205* and 210*, not till a couple hundred miles later did she run at 180*. I never left the 195* in that long but dont want put that many miles on her at 240*.
Charlo
hectre13
Dec 11, 2023 08:14 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
cstrobel65
Aug 15, 2015 10:19 AM
mcgarnicle
Aug 12, 2015 04:58 PM
Irocohio
Aug 12, 2015 08:03 AM
