Fan shroud help cool?
Old Jul 6, 2003 | 04:36 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
My car runs at a constant 160 degrees (on my POS stock guages anyways) but if I sit it will creep up to slightly over 200 degrees.
I have a mechanical fan by no shroud. Do you think a shroud would help with cooling at idle?
Old Jul 7, 2003 | 05:21 PM
RPM WOT L 98's Avatar
Yes. The rule of thumb is that if your fan is more than 2 inches from the radiator then you need a shroud in order to successfully pull air through the rad and not around it. Your fan is what keeps it cool at idle, so it's not pulling enough air through the rad if it's running hotter. At highway speeds the air is forced through the rad and therefore runs cooler. If you are missing the stock shroud then put it back on, if it's a custom setup then put the fan w/in 2 inches of the rad and you should be ok.
Old Jul 7, 2003 | 08:10 PM
Transmission: 4l60e
I have a mechanical fan now..its probably about 3 inches away from the radiator. Im gonna get the shroud soon for function and for safety...that flex fan looks dangerous.
I need to get that so I dont cut my arm off one day.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
