Air Dam Modification
Old Jul 9, 2003 | 12:18 AM
larsulrik's Avatar
Car: 1992 RS
Transmission: A/T
The air dam on my 92 RS is perpendicular to the ground. It would seem more beneficial to me to have it tilted up slighty as to be more of a scoop than a wind drag. Is this true? I was thinking of drilling a few holes and attaching something to give it a little bit of an angle. Also, I have big gaps between my rad and condenser and 4 big gaps between all the sides of the fan and rad. Is this very inefficient or is it just me? It's really starting to heat up in Texas so I need to take care of all the little things. Thanks
Old Jul 10, 2003 | 02:45 AM
MdFormula350's Avatar
i used some string to hold the front of the air dam forward.
Old Jul 10, 2003 | 02:51 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the air dam works by creating high pressure below the radiator and that pressure makes the air flow upward.. its not really "scooping" anything.. IMO, i dont think tipping it forward would help it much if at all....
and if you did, you would want it longer then stock so that it was still just as low to the ground..
also, theres suppost to be a gap between the radiator and the AC stuffs.. otherwise, niether would work as well...
as for the gaps on the radiator around the fan, yea, a fan shroud might help... athough i thought they came stock..
Hotrodboba400
Dec 10, 2019 07:07 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
edoff13
Sep 11, 2015 03:55 AM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
