How much water if any do you need ...
Old Aug 7, 2003 | 03:21 AM
dunsplus's Avatar
well i see i coolant resevoir but where does the water go? i dont see a place to add water to it.just the coolant resevoir and if so what is the water ration to coolant.thanks alot guys
Old Aug 7, 2003 | 06:41 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
50/50 mix coolant to water for most applications. Very warm climates where freezing is not an issue you can go as low as 70% water 30% coolant. Any lower and the coolant can't keep it's corrosion inhibitors active.
Old Aug 8, 2003 | 05:28 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yea, somewere in the area of 50/50 to 60/40 is about right.
(water/coolant)
Old Aug 20, 2003 | 09:25 PM
onebinky's Avatar
Re: How much water if any do you need ...
Bofore you add coolant to the overflow tank, you want to make sure the radiator itself is full. You can do that by pulling the cap when the engine is cool.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
Mark_ZZ3
May 24, 2018 01:02 PM
383backinblack
Oct 14, 2015 08:50 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
