coolant fluid everywhere...
Old Aug 24, 2003 | 06:27 PM
pawsino's Avatar
hi, i'm having a problem with my 86 TA.
I recently noticed a leak coming from the engine somewhere, when i look under the car its coming from around the flywheel somewhere, i know its not coming from anything but the rear of the engine, where can this coolant possibly be coming from???
car runs fine, no coolant in the oil, no coolant coming out of exhaust, but its definately leaking from the rear of the engine, any suggestions where???
thanks...
Old Aug 24, 2003 | 09:08 PM
MdFormula350's Avatar
where the two hoses go to the heater core at the firewall, look around from the passengers side. it most likely is leaking from there.
Old Aug 25, 2003 | 01:12 AM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Like MdFormula350 said. I had a leak awhile back that was in the same location as you said. I first replaced the heater hose that connects the hard line under the engine to the firewall. It still leaked, so then I just connected the two heater hoses together off the firewall. Never had a leak since.
sheachopper
Jul 31, 2019 11:27 AM
mfp189
Sep 27, 2015 09:25 AM
