aluminum radiator
Old Sep 15, 2003 | 12:15 PM
FatJ's Avatar
Car: 88 GTA
aluminum radiator
anyone know where to get a decently priced aluminum radiator? mine is seriously screwed, after my car almost overheating the rad was only hot on top, and cold on da bottom, pretty sure that means i need a new one. anyways, any help would be appreciated.
Old Sep 15, 2003 | 12:21 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2432715142
Bling.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2432906380
Bling.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2432518141
Bling.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2432904778
Bling.
www.ebay.com Bling Bling Bling Bling Bling....................
https://www.thirdgen.org/techbb2/search.php Bling Bling Bling Bling Bling....................
S-D
Old Sep 17, 2003 | 11:29 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Bling.
LMAO! you do realized you linked him to a radiator for a 4 cyl iron duke 3rdgen right?!
Old Sep 18, 2003 | 11:58 AM
FatJ's Avatar
Car: 88 GTA
i didnt even bother with his links, i have already looked on ebay. I was hoping someone knew an online shop that sold them new, for a decent price.
Old Sep 18, 2003 | 12:59 PM
Car: 1991 RS
Two of the e-bay links are online shops/dealers. So, why bother with those? Don't bother, you already looked.
I also inlcuded a link to the search engine for this site. Did you try that, or just 'not bother' with that, as well?
Search aftermarket products board for "aluminum radiator".
https://www.thirdgen.org/techbb2/sea...der=descending
bEST oF lUCK
S-D
BTB Mr Dude- I posted the 4 cyl. ad because it is a online radiator shop, indicating they may have the correct radiator.
Old Sep 28, 2003 | 06:22 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
Damn, swerve, try to help, and get the big "don't bother",,, hope he remembers that next time he needs help..
Old Sep 29, 2003 | 01:58 PM
FatJ's Avatar
Car: 88 GTA
I didnt mean to be harsh about it, its just every time i post a question, some witty jerk (no offence swerve) decides he should post his ramblings about how people dont search first and dont look on ebay for this crap.... I was looking for a new radiator, and i dont want to deal with some ebay shop that carries "basically new" radiators. I did do a search first, and i didnt find anything promising, so i was hoping to find someone that knew somewhere or someone who can get them for cheap...
sorry about sounding like a dick and all, i appreciate that u were trying to help swerve, im just sick of ppl telling me to do things ive already tried.
anyway im done rambling, back to work *mutters*
Old Sep 29, 2003 | 02:01 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
supposedly the griffin 31x19 aluminum radiator works in our cars with a little work to make fit.
Old Sep 29, 2003 | 02:05 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i stuffed a generic BeCool radiator in my 82.. all i did was measure the space that the old one was in....
athough i do recall having to cut a corner of the lower sheetmetal off for more room around the hose.. and i had to "tweak" everything to make it fit... but that was mostly because i got the biggest that would fit in there.
Old Sep 29, 2003 | 02:10 PM
FatJ's Avatar
Car: 88 GTA
the griffon fits but it takes a lot of effort to put it in... cheesex did it on his car and i saw it... man that thing is big...
Old Sep 30, 2003 | 09:41 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
The following is a copy of an e-mail--should probably be posted in "product review"--but fits here. This guy sells custom built rads for almost any application. He usually has some on E-Bay from time to time. Mine was $385.00 for a custom built aluminum 2 row with 1 inch tubes. As good as any "BE-Cool" I have ever seen including shipping (I think). He normally lists products under "Radman 1953"
To: randy pettey rpettey4@comcast.net
Sent: Monday, September 29, 2003 12:15 PM
Subject: radiator
Randy,
Just wanted to let you know that I finally got the radiator installed that I got from you for my 89 IROC Z Camaro. It wasn't a complete "bolt-in" like I thought it was going to be, but it was a minimum of work. Because of it being thicker I had to modify the top shroud (the bolt holes were about an inch too far apart from lining up. If I had the resources (or was worried about cosmetics), I probably would have made a new top shroud from aluminum. As it was, I used some perforated strap and speed clips on the middle 2 bolts, and just drilled a couple new holes for the 2 outside screws. I also had to grind small clearance notches at each end to fit over the side tanks. I did have to space out the factory dual fans as you said I might have two. I used 3 5/16 washers in between the fan and bracket on all the holes, for spacing it back Everything else fit very well--IE: it dropped into the radiator hole/space perfect! Hoses matched up just fine.
With A/C on just normal driving around town, it would get up to 230/235 (if I let it). Now it runs about 205 (195 on highway) in same conditions--without A/C it runs about 195 (185 on highway) with a 180 t-stat, and this is with putting the fans back to the original OEM wiring, instead of hot wiring one or both to run whenever ignition is on.
I know with all the different rads U build, U can't remember minor details about all of them, so if U want to save this e-mail to refer to or send to a perspective customer, U certainly have my permission!
Thanks for saving me $200/300 over a "Be-Cool" version. It was a real pleasure doing business with you, especially with U taking time to answer ALL of my questions
Thank You
Craig Landry
Old Sep 30, 2003 | 03:13 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I have the generic 31 x 19 Griffin dual 1" core radiator...It fits with minor effort in my opinion. I had to notcht the lower support to clear the tanks. I am using Spal fans and made my own simple upper hold down so all that made my swap even easier...You could retain the stock fans and the upper support by simply cutting and fitting as neccessary...Have fun
BTW, it works great...
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
jrdturbo
Mar 31, 2016 02:58 PM
lanceflame44
Sep 25, 2015 12:28 PM
