what else can u do?
Old Sep 18, 2003 | 07:19 PM
icebird_1981's Avatar
what else can u do?
i was wondering what else can u do to keep your car nice and cool other then a ram air hood/crawl. i have an older 350 block were the fan is alway on also my z28 is carbed with a open element air cleaner. what else can i do?? should i invest in a diffrent fan blade? would it make a diffrence?
Old Sep 18, 2003 | 07:30 PM
mikes92rs305's Avatar
a high flow water pump from stewart should help
Old Sep 19, 2003 | 05:58 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
How cold do you want to make it?
Old Sep 19, 2003 | 10:05 AM
well u notice how when u first start your car in the morning it feel alot faster it would be nice if i could get it like that all day. but i dont think that is gunna happen, so i wanna make it as cool as possible.
Old Sep 19, 2003 | 01:04 PM
Z06's Avatar
Z06
HAVE YOU CHANGED THE RADIATOR? MY 91 Z28 WAS ALWAYS RUNNING CLOSE TO 240F AROUND TOWN. i CHANGED THE PLUGS, WIRES, THERMOSTAT(TWICE), SENSORS, CHECKED MY TIMING & FLUSHED THE RADIATOR. I RECENTLY PURCHASED A BE COOL CUSTOM FIT RADIATOR, ALL ALUMINIM DUAL 1 INCH CORE AND KEPT MY OEM ELECTRIC FANS. BOY, MY PROBLEM WAS SOLVED!! I NOW RUN AT 180F. IT'S EXPENSIVE BUT, TO ME, WELL WORTH IT FOR THE LOWER TEMPS.
Old Sep 22, 2003 | 10:33 AM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Z06 is right. I went to a 2-fan set-up, and a custom-fit Be-Cool rad., and now I can finally run a 180 stat. It's the ONLY thing that fixed the problem.
Old Sep 25, 2003 | 11:07 AM
kahamri's Avatar
Car: Camaro
Engine: More than one
Transmission: More than one
Yeah, you should upgrade to the dual fan setup..and get a high flow raidator...That'll get you down..the water pump would be good too...get a decent aftermarket one...other than that and the hood...there's not much else you could do...what kind of intake do you have on it...maby a cai would help..and some well placed heat pads..
