Anyone ever try this?
Old Sep 27, 2003 | 03:05 PM
guza's Avatar
Car: 1985 Berlinetta
Engine: 305 4BBL
Not third gen but my 94 minivan just blew a head gasket. I guess, white smoke and antifreeze coming out the exhaust. With 300,000 miles on it, I really dont want to replace the head gasket.
Someone told me to drain the antifreeze and bypass the heater core. The add SODIUM SILICATE (water glass). Run the car and it will seal the gasket and some small cracks.
Anyone try this or have experience with this? How long will this last?
With that many miles I may try it, nothing to lose!
Old Sep 27, 2003 | 03:40 PM
lykan's Avatar
I used it in my dearly departed '67 dodge pickup. It sealed some of the minor cracks but gunked up the inside a bit too.. If you dont care about the radiator go ahead other wise, fix the gasket. I never used it on a bed head gasket tho wonder what it would do insid e the chambers..ick
Old Sep 28, 2003 | 09:36 PM
guza's Avatar
Engine: 305 4BBL
Well it seems to have worked. I put the sodium silicate in and let the car run for about 30-40 minutes. It started to build pressure and then the white smoke stopped.
Drove it last night and a lot today, still no smoke or loss of coolant.
Old Sep 29, 2003 | 07:49 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It's just a band-aid fix...you're gonna have to dig into it sooner or later so be ready.
Pete
Old Sep 29, 2003 | 10:17 PM
guza's Avatar
Engine: 305 4BBL
With 300,000 miles there won't be much to dig into I know it is just a bandaid but hopefully it will last while I research an negotiate a new car. It looks much better pulling into the dealer without all the white smoke!
Old Sep 30, 2003 | 09:44 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
K+W block sealer--GOOD STUFF
Used it in Stock Cars and sprint cars at Circle track and finished out the night!
GOOD STUFF!!!
