non A/C heater blower
Old Oct 15, 2003 | 01:29 PM
brooklyn's Avatar
Will the stock heater blower work, once the A/C system is removed completely?
How to configure non A/C heater box with existing electrical connections, and stock heater blower?
Old Oct 15, 2003 | 05:41 PM
MdFormula350's Avatar
http://members.***.net/iroczdave1/IR...rts%20Page.htm
u take the whole box out its one big piece, which has one motor that spins 4 speed for either heat or a/c.
the new standard heater box has only 3 speeds, which goes through the resistor block.
now if u have just the heater box and no motor, use this article to use your stock a/c fan motor.
good luck.
Old Oct 15, 2003 | 09:43 PM
Kandied91z's Avatar
what article?
i've been trying to get my heat working since i did the swap. i replaced the original motor with the one your describing as well as a new resistor and every time i go to turn it on the fuse blows now.....
Old Oct 18, 2003 | 02:07 PM
https://www.thirdgen.org/techbb2/sho...ht=a%2Fc+motor
sorry.
jrdturbo
Mar 31, 2016 02:58 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
