Electric Fan for HO
Old Dec 6, 2003 | 11:08 AM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
Electric Fan for HO
Ordered replacement water pump today, wondering how hard it would be to go to electric fan. I would like to route it to a thermostat (not a switch), and was wondering what kind of problems or how much of a b**ch this would be.
Old Dec 6, 2003 | 11:40 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Get a hayden fan switch, they are thermostaticly controlled. I have one in my car (part number 3653 no ac relay as i have no ac) I bought that and a relay, It comes with a probe, the directions say to zip the probe to the rad, i didnt do that instead i zipped it to the upper rad hose because the hottest coolant in the rad is comming from this hose. You then wire the switch to the relay. Run a constant hot to the batt and a key on source to the relay. The key on source does not have to be thick high amp drain wire because it only turns the relay on, the relay then opens a direct current from the battery power to the fan switch, the switch then turns the fan on at a temperature set for it to come on. I installed the switch along with a 180* thermo, and set the switch for the fan to come on at 180*. ***** has a thread on this also. ITs VERY easy to do.Just be sure you get a high enough cfm fan for your motor.
Old Dec 7, 2003 | 02:34 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
u sure u got an h.o.? I thought all h.o.'s came with electric fans and lg4's came with crank driven?
Old Dec 7, 2003 | 11:26 AM
br()bert's Avatar
Car: 85 firebird
My friend has an 83 z with a belt driven fan also.
Old Dec 7, 2003 | 08:20 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
It's belt driven, very sure. Because the fan bearing was worn out. And it has a pulley attached on the end. Thanks for the tips, will try to hook up electric fan; left it apart so me/my dad can replace the hoses.
sheachopper
Jul 31, 2019 11:27 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
