Engine is running cool w/ new 195 thermostat
Old Jan 7, 2004 | 08:32 PM
marineengineer's Avatar
Car: 1992 Z-28 Convertible
Engine: 305 LB9 TPI
So have this new(used) 92. I wanted to flush the coolant and install a new 195 thermostat. No problem so far. Filled the radiator, started the engine and noticed I have coolant flow thru the radiator with a cold engine and a new thermostat. Pulled the thermostat to make sure it was installed correctly(it was) , but now the engine runs about 150-160 and I still have flow thru the radiator even when the engine is cold. It would seem that I am bypassing the thermostat and the engine never reaches operating temperature. What gives? Have I missed somthing here? When the engine is running, I have good heat, not great, but I get heat. Is it possible to have flow thru the radiator even though the thermostat is shut?
Old Jan 7, 2004 | 09:06 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
is your heater core hose connected to pump or radiator tank ?
Old Jan 8, 2004 | 11:26 AM
VetNutJim's Avatar
Car: Different One Every Day
Engine: LS1,LS6,L98,L83
Transmission: 700R4, 4060E,Turbo 350, Turbo 400
Sounds like you got one of those "South of the Border" thermostats.
I've had SEVERAL that were so far off it's not funny.
Last one was a 180 degree that runs at 154.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
85Special
Sep 3, 2015 04:21 PM
