water pipes what are they for?
Old Jan 12, 2004 | 02:17 PM
The gta master's Avatar
Car: Pontiac Transam Gta
Engine: L98 350
Transmission: Th700r4
hi
does any one know what the two water pipes are for that come from underneath the sump and bolt via a bracket to the fuel pump blanking plate and lead to the radiator and heater matrix
please dont confuse these with the oil cooler pipes....these other pipes contain water....
any help would be appreciated as i cant get under car to trace them...
Old Jan 13, 2004 | 12:06 PM
Engine: L98 350
the car is a 1989 pontiac transam 5.7 Gta Auto.
Any help would be appreciated.:lala:
Old Jan 13, 2004 | 12:18 PM
Engine: L98 350
Or does anyone have a pic or link to a diagram of the cooling routing system (not a wiring diagram)(a pic of where all the pipes go )
I have tried a search but no luck only wiring diagrams found.
Old Jan 13, 2004 | 07:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: water pipes what are they for?
The factory oil cooler lines carry coolant, not oil.
Old Jan 27, 2004 | 10:56 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Maybe a pic will help?
This is the best one that I have but I think I explained the routing somewhat...
Old Jan 27, 2004 | 06:06 PM
breathment's Avatar
this?
Old Feb 9, 2004 | 09:46 PM
Flamingo's Avatar
Car: 89 GTA
Engine: 5.7 TPI
seeing that diagram reminds me....
right above the t-stat housing underneath the throttle body is a pipe that looks like it should have a decent size hose (like heater hose size) hooked to it. What should be hooked up to this, and does it hurt anything not having anything there? Nothing is leaking from it, so I guess there is nothing hooked to the other end either. Is this where the coolant used to flow thru the intake and somebody already did the bypass mod?
tia James
Old Feb 10, 2004 | 08:39 AM
breathment's Avatar
correct.
sheachopper
Jul 31, 2019 11:27 AM
Night rider327
Oct 9, 2015 09:25 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
