Where's all my coolant going??
Old Jan 12, 2004 | 02:48 PM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
About every 3 weeks I have to add coolant to my radiator in my IROC for some reason. I don't see any leaks anywhere but when the car is running sometimes I can smell antifreeze......inside and outside the car. I'm hoping it's not a head gasket but knowing my luck it prolly is although it doesn't smoke or blow anything out of the exhaust.
Anything else I can check before the worst case scenario?
Old Jan 12, 2004 | 06:26 PM
MdFormula350's Avatar
things to tighten.
the two hoses on the passengers side firewall that connect to the heater core. those leaks sometimes and the coolant burns off on the manifolds/exhaust.
places to look, the water pump weep hole, that coolant can dip and dip and u dont see it.
umm the thermostat housing, around that area, could be a bad gasket or the bolts are not tight enough.
Old Jan 13, 2004 | 10:00 AM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Check your carpet on the passenger side too, because your heater core may be leaking. Mine was dripping antifreeze out from under the dash and making hte carpet wet. Happens a lot.
Old Jan 13, 2004 | 10:42 AM
Dano 00TA's Avatar
Engine: LS1/L98
Gonna check your ideas out today.
Old Jan 13, 2004 | 10:50 PM
fratsit's Avatar
Car: 1992 Camaro Z28 and '99 Camaro Z28
Engine: 350 TPI Supercharged
Transmission: Pro-Built Street/Strip 700R4
Axle/Gears: Stock
How old is the radiator cap? Could be worn and time for a replacement.
Mine was doing the same thing....replaced the radiator cap and the coolant stopped evaporating.
Fratsit
Honolulu
Old Jan 15, 2004 | 11:54 AM
XThree's Avatar
Car: 91 RS
Transmission: TH 700 R4
The intake manifolds rear seal on our 3rd gens are notorious for leaking coolant out the back near the distributor, down onto your driveshaft, and makes its way back that way when you drive your can and its warmed up and you never see it dripping. If you can't find any of the other leaks mentions above this might be whats happening. You can go through the trouble of re installing your intake manifold with new gaskets or just keep checking your coolant level often.
Old Jan 15, 2004 | 10:16 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
intake internally? Mine was
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
