89GTA TPI Does AC Air go through Heater core?
Old Mar 21, 2004 | 08:24 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
Assuming I were to remove the Heater control valve and the heater core had heat all the time.. If I were to switch on the AC, or just vent air.. would it be hot/hotter? IE would the air go through the heater core? I assume not but I'm doing an LT1 Swap and I'm at the stage of running new heater hoses.. WOuld like to dress up and simplify things.
Old Mar 21, 2004 | 09:28 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
no, A/C cooled air does not go through the heater core(in the A/C selector position)
Old Mar 21, 2004 | 11:56 PM
breathment's Avatar
what about when you have the a\c on, but temp selector on heat? does it go through the heater core first? or does it seperate and go through each individualy?
Old Mar 22, 2004 | 06:13 AM
Dave Y's Avatar
Engine: 4.3L V6
it then goes through the Evap(A/C) then through the heater core(air always goes through the Evap(A/C))
Old Mar 31, 2004 | 07:30 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
do you know how to add a heater coolant shutoff valve? my a/c doesn't work and the heat just pours out of the heater core. i heard the fix is to install this valve....but how to do it?
Casey Meyers
Mar 2, 2016 10:46 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Street Lethal
Aug 14, 2015 08:25 PM
