Vibration when using vents
Old Apr 4, 2004 | 12:19 AM
305PhoenixAm's Avatar
Car: 85 Trans Am
Engine: 383 TPI (Yes, TPI. Not for long though)
I can't very well search this cause it's a broad subject, and I have no idea what could be causing this. I'm relatively sure this is the right place for the thread though.
Whenever I turn a vent element on, AC, Heater, vent, whatever, I get a vibration throughout the whole car. The first time I felt it I thought it was coming from the back end somewhere, under the car. Now, I can't exactly tell where it's coming from, but I know I can feel it in the seat rather than anywhere on the dash. It seems to mostly happen severely with AC on while coasting or slowing to a stop, and there only seems to be a small hint of it when the heater is on or at idle. The car only does this with AC or heater (any of that air stuff) turned on. I may be wrong about the vibration with the heater on though, I wasn't paying too much attention today. Was focusing too much on the excitement of being able to drive it after a long period of garage time. But I'm sure it happens with AC. It's way too hard to ignore. Any ideas?
Old Apr 4, 2004 | 09:59 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Sounds like you have a vaccum leak. One of those old vacuum lines running around the heater controls may have gone bad. Or the switch itself might have gone bad.
Old Apr 5, 2004 | 12:13 PM
Car: 85 Trans Am
I didn't think there were vacuum lines anywhere near the heater controls. I can look, I guess. Which switch are you referring to? I don't know how the heater switch itself could cause vibration. I realized last night I can feel it in the steering wheel, so I might have been wrong about it being under the car, per se. But I still don't know what could cause it.
Old Apr 5, 2004 | 10:39 PM
dankhound's Avatar
Car: 91 RS
The doors that divert air are controlled by vacuum. The vacuum lines run all the way to the controlls and then to the doors.
Old Apr 6, 2004 | 07:54 PM
IrocZS383's Avatar
Car: 1986 Camaro
Engine: 357
Transmission: 700-R4
The vibration could be caused by your compressor locking up. That means it is going to fail soon. That is exacly what mne did. Just my 2 cents.
Pac J
May 17, 2020 10:44 AM
Fanatic1074
Oct 2, 2015 03:47 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
