Radiator Pitcock
Old Apr 5, 2004 | 06:42 AM
CamaroRS91x's Avatar
Radiator Pitcock
hey guys,
sorry for the stupid question but....
I'm wanting to drain my coolant and I've never done it before. Does anyone have a picture of what the radiator pitcock looks like, and how you drain it? Also, once I drain it, is there anything else I should do - or just replace the tstat and refill it?
Thanks!
Old Apr 5, 2004 | 12:23 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
petcock is at the bottom of the radiator and looks like a giant screw with a wingnut type tip on it. just remove it and let the coolant pour out. now would be a good time to buy a radiator flush kit and use that as well. then fill it up and your done.
Old Apr 5, 2004 | 04:29 PM
sl2_99's Avatar
Car: 1988 CAMARO
Engine: 2.8
Transmission: 700R
i believe 90-92 had plastic tanks on the radiater which doesn't look like a wing nut if im not mistaken where as the 84 had a metal tank and it looked like a wingnut hopefuly you can see the pic of what yours should look like.
Old Apr 6, 2004 | 09:13 PM
elcamin0_77us's Avatar
Car: 77 El Camino
Engine: 355 Converting to TPI
Transmission: Converting to 4L60/4L60E
Secondly, its not suspose to come out. Its designed to be screwed in or out, like on a water faucet.
Bill
Old Apr 7, 2004 | 12:00 AM
onebinky's Avatar
on my 85, 87, 92, and 01 F-bodies they all looked like that as well. Can't recall what the 81 was
I usually just pull the lower hose off the radiator and let it drain that way. It's always been easier for me
Old Oct 15, 2008 | 01:58 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
Re: Radiator Pitcock
i pulled my hose off yesterday to drain mine but i dont think i got it all? what is the best way to really flush it? my coolant is muddy color it needs to be done! and i need to replace heater core i think its clogged wont heat anymore.so i bught one and need to thoroughly flush before putting it in
Old Oct 15, 2008 | 05:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
why reopen a 2004 thread to ask how to flush your rad?
run a hose into the top to fill it as you drain it. Also remove your knock sensors, and drain your block. fill it from the waterneck and let it drain from the knock sensor holes as well. Use a flush if you want.
Then plug it all up and refill with 50/50 or whatever you prefer.
sheachopper
Jul 31, 2019 11:27 AM
lanceflame44
Sep 25, 2015 12:28 PM
