fan shroud
Old Apr 16, 2004 | 02:10 PM
Beartracks's Avatar
Car: 92 RS
Transmission: auto
fan shroud
Does anyone have a picture of the twin radiator fan setup? I wonder if I might be missing some kind of shroud as the fans sit away from the radiator a bit.
Old Apr 16, 2004 | 10:21 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
There's no shrouding piece.. There is an upper support bracket (this is what holds the radiator and what the fan brackets bolt to up top), and there is a lower bracket that gives the fan brackets a place to bolt to down low... The fans sit an inch or less away from the radiator...
Old Apr 19, 2004 | 09:16 AM
Beartracks's Avatar
Car: 92 RS
Transmission: auto
Hmmm. I guess I got it all. Still have a little trouble in the summer getting up to 220 once in a while. Probably need a larger radiator. I've already got the temp switches.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
