overhead fan
Old Jun 23, 2004 | 07:28 PM
boomaceboom's Avatar
Car: 1984 Camaro Z28
Engine: 305 V8 High Output
Transmission: 700-R4
overhead fan
has anyone ever thought of putting a fan underneath the hood of the car? why hasnt it been done, does it not do enough for cooling to make a difference? I know the fans normally take air from the radiator, but could an overhead fan try and get all that hot air down.
Old Jun 23, 2004 | 10:21 PM
what i mean is a fan that is pushing air from the top of engine to below, where it reaches the ground.
Old Jun 24, 2004 | 02:51 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
i can see many issues you would encounter.
Hood clearance
Mounting
Wiring
Where does it draw air from
In short, unless you have about 5" of hood clearance, it won't work. Stick with what works (keeping the fan by the radiator) and be content. Almost an entertaining idea.
Old Jun 24, 2004 | 10:31 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
the fan isnt to put air onto the engine anyways... our engines are designed to be water cooled. hot water enters the radiator which in cooled by oncoming air. at rest there is no oncoming air so the fan is there to draw air into the radiator
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
