single core radiator??
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
When I pulled the radiator out of my (red) 86 IROC (TPI and 700r4) it had a single core radiator in it. I couldn't believe it. I haven't checked the black 86 IROC (TPI/700r4) yet. The black car only runs at correct temp. (within 5 degrees of normal) when the weather is cold. My 83 Z28 on the other hand, has similar set up, never seems to get "too" warm but we replaced the radiator several years back with an aftermarket 2 or 3 core radiator (don't remember exactly). Is a single core radiator factory stuff or did someone put a cheaper one in this car before I bought it?
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
all thirdgens came with aluminum core plastic end radiators with one single 1 inch core
the reason the 83 seams to stay cooler is because of the clutchfan because on my buddys 84 firebird it does the same thing
LT1Formula
Oct 8, 2015 08:34 PM
