Fan contoll, ECM or switch?
Old Jul 26, 2004 | 06:28 AM
SNET Telly's Avatar
Car: 92 1LE B4C
Does the ECM controll the fans or the temp switch on the pass. side head. I know there is enable and disable temp for fan1 and fan2 in the ECM, but then what does the switch do?
Old Jul 26, 2004 | 04:56 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
The ECM uses info from the coolant temp sensor(in the front of the intake manifold) to control the primary fan; and working independently from the ECM, the fan switch(in the passenger side head between plugs 6 & 8) senses the temp to trigger the secondary fan.
Old Aug 1, 2004 | 03:21 PM
Kandied91z's Avatar
how could i temporarily wire up a switch so i can turn them on when i want?
Old Aug 1, 2004 | 10:35 PM
SNET Telly's Avatar
Car: 92 1LE B4C
I need to look at a wiring diagram, But I would think to hook it up to where it thinks the A/C is on, so both fans come on.
Old Aug 6, 2004 | 03:48 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Will the secondary fan still work if you remove or disconect the AC?
Kevin
Old Aug 6, 2004 | 06:37 AM
SNET Telly's Avatar
Car: 92 1LE B4C
the secondary fan works from the temp switch and doesn't care about the A/C. I think the cpu tells the fans to come on when the A/C is on, but haven't had any replys on my post over in DIY proms yet.
krisner89
Oct 10, 2015 06:03 AM
bryanwood74
Sep 24, 2015 09:50 PM
mddaniel
Sep 8, 2015 05:16 PM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
