Northern Aluminum Radiator=The Sheezy!
Old Jun 30, 2005 | 12:58 PM
  #51
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
try to remember that when you run a non-reinforced lower hose (no metal coil inside) that you run the chance of it collapsing while on the highway.
This is the problem, a series of events that the spring was designed to stop:
1. When your hose gets hot and soft and pliable.
2. Then you are driving down the highway at a decent RPM.
3. Then the hose will collapse and "pinch off" the flow of coolant.
4. Make sure that if you remove the metal coil that you remove as little as possible.
5. It still might happen in the spot you removed it.
just some things to think about.
Old Jul 1, 2005 | 04:53 PM
  #52
KintaroOe's Avatar
Car: '91 bird '87 Z28 '86 T/A
Engine: LO3 LG4(ls1 in works) 350
Transmission: 700R in all
Axle/Gears: wimpy 10 bolts
dude, yall need to chk out advance auto parts, i bought a stock replacement radiator for $98.
Old Jul 17, 2005 | 07:49 PM
  #53
ditchbangr's Avatar
Car: One of 5
Engine: LB9
Wow I got a deal. I am from Willmar, MN and my sister in law works at Northern. I paid 156.00 for my radiator on the employee plan.
Old Jul 17, 2005 | 11:22 PM
  #54
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
i smell a group buy with a employee cookin
Old Jul 18, 2005 | 07:30 AM
  #55
wilyk9's Avatar
Car: 85 Trans Am
Engine: 305 Carb
I agree that is the best route if you are looking for just a replacement, but I am looking for more than that. Want aluminum so it can be polished, plus a bit more cooling capacity. I know about BeCool, but $$$$! This one is a bit easier on the budget while still matching what I want.
B4Ctom1, any chance on the group purchase?
Old Jul 22, 2005 | 07:52 PM
  #56
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
possible dumb question:
what is the circled thingy for.
Old Jul 22, 2005 | 07:59 PM
  #57
Diggler86's Avatar
Car: 86 TA
Old Jul 22, 2005 | 08:08 PM
  #58
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
i got mine 31X19 from summit ....their aluminum rad and a b&M supercooler TC for 240 TOTAL shipped ...for less than 300 bucks my car doesnt pass 190* the only reason its passed this mark is bc my fans arent working ...already bought a flexalite fan ready to go in when i get the car back
bye bye heat
Old Jul 22, 2005 | 11:38 PM
  #59
Night rider327's Avatar
Car: 1988 Camaro
Diggler86... That's a drain valve. You un screw it and it will let out the water that's in your rad.
On some rads. there's two, so look down around the bottom rad. hose, if there's another one, then 1 is for the auto trans fuild drain, and 1 is for the water/anti frezze drain.
If just 1, then it's for the water/anti frezze.
Old Jul 28, 2005 | 03:50 PM
  #60
Drew's Avatar
Originally posted by Diggler86
Actually that's a low coolant sender. Digital dash cars might use it, but all aftermarket replacement radiators come with it.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
jrdturbo
Mar 31, 2016 02:58 PM
Royal_Z
Sep 30, 2015 08:45 PM
lanceflame44
Sep 25, 2015 12:28 PM
