help me to find them please
Car: 1991 chev cam conv
Engine: 5.0
Transmission: a
i no one thing when the temp goes in the red line i stop and look at the hoses and they look good and nothing is overheating but still watching it go to red line makes you scared i no i have 3 sensor now i have to find them on the engine i found one it was buy the stat need help with the other too please
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
On my 92Z28., there is a temp switch on the passenger side between the last 2 spark plugs and above the starter and one on the drivers side near the first sparkplug (think that one is for the temp guage) and then the one by the thermostat (temp control sencor I believe). Hope that helps, pay no attention to the spelling.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The one by your starter is the fan switch. the one on the driver side by the #1 sparkplug is the coolant temp sending unit for the temp gage in the instrument cluster and then you have the coolant temp sensor in the from of the intake manifold below the throttle body if you have a TPI engine. If you have a 305 TBI engine the coolant temp sensor is on the right side of the engine behind the A/C compressor and the other units mentioned are in the same place previously mentioned.
MikkoV
Sep 9, 2015 04:25 PM
Street Lethal
Sep 7, 2015 01:09 PM
