fan problems help
Old Oct 6, 2004 | 04:46 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
fan problems help
I have duel electric fans and they occasionaly stay on and drain my battery dead. Is there staying on caused by a bad temp switch? Any help would be great.
Old Oct 6, 2004 | 11:53 AM
91Z-TheReaper's Avatar
Car: 88 IROC
Engine: 350 L98
Transmission: T5 - 5 Speed
I don't know why they/it would drain your battery?
I run my fans constant (100%) and have no problems like that...
Old Oct 6, 2004 | 01:24 PM
patRIOTik's Avatar
Car: 1986 Chevy Camaro Z28
Engine: 4BBL 350
perhaps he means after the car is turned off.....
Old Oct 6, 2004 | 02:06 PM
Car: 88 IROC
Engine: 350 L98
Yeah, I thought about that after I posted...
The only thing that I could think of would be to install a toggle switch or something similar (so you can cut power to the fans when you kill the engine).
Everyone who owns a thirdgen knows that our cars run hot. Just the way it is.
Old Oct 7, 2004 | 10:41 AM
doc76239's Avatar
Engine: TPI 305
Hmm
Is there a switch that is controled by tempurature, taht turns the fans on and off?
Old Oct 7, 2004 | 01:09 PM
91Z28-350's Avatar
The fans are controlled by 2 relays that is enabled only when the ignition is on.
Is your set up stock? If so, check your relays.
krisner89
Oct 10, 2015 06:03 AM
utfan01ss
Sep 28, 2015 12:17 PM
Papaginos
Sep 27, 2015 03:29 PM
JHX
Aug 29, 2015 02:30 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
