Passenger side fan--not getting any power?
Old Oct 29, 2004 | 05:27 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
I have a dual fan setup on my 91 Z28. The second fan is not coming on (passenger side).
I have tested both fan relays and both fan motors, which are fine and working properly.
I feared it was the sensor in the block that wasn't working properly, so I tried installing a manual fan switch (as a test) to ground the green and white wire going to the passenger fan's relay. It is grounding the wire, yet the fan won't move. I tried it on the primary fan (drivers side) and it worked fine. Because of this, I tested the fan motors by swapping the primary fans wire harness onto the second fan. And then tried swapping the relays.
I think my problem is that the second fan (passenger side) is not getting power through the wire harness. I've checked the fusible links and fuses and all are good.
I am a real novice when it comes to electrical wiring and using a voltometer. What should my next step be?
Old Nov 1, 2004 | 11:28 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
i can't recall completely, but is that the one that should come on when you kick on the a/c? have you checked that by turning on your a/c to see if it comes on? if it doesn't then it might be because of a bad pressure switch in the a/c line. that's the one that runs down by your pass fender right above the frame - a little 2-wire switch in the a/c line. disconnect that and jump the connector. i don't know for sure if that'll help, but maybe...
KAM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Cameeeero
Aug 20, 2015 03:06 AM
Nj1987
Aug 19, 2015 08:26 PM
Street Lethal
Aug 14, 2015 08:25 PM
