Help please
Old Nov 1, 2004 | 07:01 PM
Zero2029's Avatar
Car: 1986 T/A
Transmission: 700 R4
Help please
I have a 85 tpi t/a last week my car started to overheat so i changed the themostat went from 195 to 170 then it still ran hot the bottom rad hose has a spring in it and the top looks new the elect fan runs all time i have manualy blead the system anyone with any suggestions
Current car
1985 Trans am 305 tpi
Past cars
1986 T/a GTA 350 4bbl
1986 Camaro 3.1 mpi
1995 Camaro 3.4 fi
Old Nov 1, 2004 | 07:19 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Take top plate off radiator area and check between the radiator and the AC condensor. This area will fill up with leaves and so forth and block air flow. Take a garden hose and spray out the radiator from back to front as good as you can. Brush off front of AC condensor. If no help, take off radiator cap, drain down coolant a couple inches, start engine, look for good circulation from cores when engine gets hot.
Old Nov 1, 2004 | 07:22 PM
Zero2029's Avatar
Car: 1986 T/A
radiator is clean and so is condenser the car will never overheat ideling but once u start driving it will overheat
Old Nov 1, 2004 | 11:28 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Air dam in place?
Old Nov 2, 2004 | 05:58 AM
Zero2029's Avatar
Car: 1986 T/A
IM GOING TO CHECK IT TODAY AFTER WORK
