heater core hose routing for a 67
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
i put a tpi motor in my 67 camaro and need to know where i can run my hoses for the heater core.i know the coolant runs from the intake to the heater core back to either the rad or the water pump.the problem is that i don't have the room to run the return back to the water pump nor do i have any place to hook it up at the rad.is there any where else i could hook the return up to?any help would be appreciated.
Car: `86 SS / `87 SS
You might tee into your lower hose and route it to there. I like the passenger side tank fitting though. Maybe have that added to your rad.
Pac J
May 17, 2020 10:44 AM
