thermostat needle wont go down
Old Dec 7, 2004 | 01:04 AM
keopectake's Avatar
Car: 87 Z-28
Transmission: 5-speed
the needle on my thermostat gauge is stuck past 260 wont go down even when the car's off, do you think it's just the sensor or is there soemthing actually wrong.
Old Dec 7, 2004 | 06:28 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
well it normally stays in the same postion it was when the engine was shut off, so it sounds like your wire to that sensor is grounded out, which will make it stay pegged out and since as soon as you apply power, it's going to stay there. you need to chase that wire down and see it it is grounded out somewhere. and then, too, your sensor could be bad, but not likely. normally they don't read right or at all if they're bad - not the other way around.
Old Dec 7, 2004 | 01:07 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
thats what happened to me a couple of times. Both times was the temperature wire was touching my header manifolds. Check the driver side header manifold to see any wires touching.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
BWilcox
Sep 20, 2015 12:19 PM
