Connector Identification Help
Old Jan 11, 2005 | 11:39 PM
galletti's Avatar
Car: 1988 IROC Convertible
Hello,
There is a connector that looks like a sensor coming out the passenger side of my radiator about half way down facing the rear of the car. It has a male spade connector on it. Problem is there is nothing connected to it and I don't know what it is or what it does. There don't seem to be any loose wires in the area. Any help will be greatly appreciated.
Old Jan 12, 2005 | 12:44 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Don't worry about it, it used to be used as a low coolant sensor on some model vehicles. It is not a system that is used on our vehicles. On my 89 Iroc there is a brass plug in the radiator where that sensor used to be. Your radiator was probably swapped out at some point in time with a radiator from a car that used that sensor.
Old Jan 12, 2005 | 06:54 AM
galletti's Avatar
Thanks a lot. Indeed, this car suffered a pretty bad front collision at some point and most of the front was changed out. Would you happen to know what size brass plug I could use for this.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
