Ahh Help Someone!!!! Fan Troubles!
Old Jan 14, 2005 | 09:26 PM
86irocznj's Avatar
ok so a few days ago i redid my valve cover gaskets and what a wonderful job that was everything came out well and i put everything back together and everything worked, last night i took it out for a spin and broke down in a gas station due to forgetting the charging plug that goes from the alternator to the battery, well with this i had to have it towed and i had a shop fix it, because it was raining and sad thing is the rain let up after i already told them to fix it ...it was 200 bucks but ok, so i got it back earlier today and drove it home fine, my problem is now my cooling fan does not work, there is a switch inside under my dash, i tested it for a circuit it works, so i checked the fuses everything works, i went into the relay that the cable from the switch under the dash runs to, the relay and the cable end tested good, so i went another step further and smushed myself under my car to check the power cable for the fan, the end that plugs into the fan works, and also the other ends(the ground and power cable on the other end of it also make a circuit)
IM completely stumped and i do not have a car to drive now, i need some help guys can anyone help me figure out whats wrong, ...this fan is 100% eletrical, with a switch inside the car to turn it on and off whenever, it just does not turn no matter what i do, i tried turning the ac on and leave it run for a few mins no luck, i let the car warm completely up, still no luck
Old Jan 14, 2005 | 09:30 PM
86irocznj's Avatar
PS!
PS: the temperature gauge doesnt work either now,
i also replaced both valve cover gaskets and everything else checked out fine
sheachopper
Jul 31, 2019 11:27 AM
mrbird
Oct 20, 2015 03:43 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
Lmancha96
Sep 25, 2015 08:11 PM
