305 heats up past the redline, then is fine.
Old Feb 24, 2005 | 10:45 AM
CaysE's Avatar
This problem is pissing me off. In the morning, I start up the car. It gradually heats up, I start driving, and the temp will keep going up, well into the red, and will eventually stutter and drop down to a normal temp. It's fine the rest of the time.
Is this a problem with the t-stat?
Old Feb 24, 2005 | 11:13 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Sounds like an air pocket gathering right under the thermostat causing a "false" temperature reading. Stat could also be sticky. Try replacing the stat. Could be worthwhile to drill a few small holes in it to allow air the bleed through.
69 Six Pack
Oct 5, 2015 07:51 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 07:20 PM
kyle5647
Aug 7, 2015 03:08 PM
