Dual fan Swap
Old Mar 27, 2005 | 01:01 AM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Dual fan Swap
There are a lot of Later model Pontiac, Buick and Oldsmobile vehicles at my local junkyard with dual fan set ups. They are all the 3.8 or 3.1 motors. Will these fan setups fit on a camaro ?
Old Apr 11, 2005 | 08:47 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
nothing you find will pop right in place. a lil fab work is always needed.
ive always found the best way to mount a set of fans is to drill some holes in the shroud and use those tranny cooler zip ties.
good luck.
Old Apr 25, 2005 | 01:04 AM
mikey R's Avatar
Car: Black 89 RS
Engine: 383 ci, TBI injected, AFR heads
Transmission: TH700R4
Axle/Gears: 3.73's
Iroc fans?
Didn't IROCS come with a dual fan set up? can I swap them to my RS and what do I need to do it? does one fan relay cover both fans or do I need two? will I need to use the IROC wiring harness?
Old Apr 25, 2005 | 08:35 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Re: Iroc fans?
im not sure if the stock setup works off 2 relays or not. stock wiring has been long gone in my car.
to swap the fans, you will need:
1.another fan connector and some wiring
2.upper shroud
3. lower shroud
4. both fans.
grab bolts clips, washers, etc if you pull them yourself. always good to have extras handy if you ever need um.
Old Apr 26, 2005 | 01:51 AM
mikey R's Avatar
Car: Black 89 RS
Axle/Gears: 3.73's
Re: Re: Iroc fans?
2.upper shroud
3. lower shroud
4. both fans.
thanks man, that helps alot.
Old May 9, 2005 | 03:10 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Stock Dual fan setups had 2 relays, one for each fan.
I would try and get a pair of the newer style GM OEM relays with the weatherpack connectors since your fans are very vital to your cars operation.
customblackbird
Aug 15, 2021 10:16 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
