All coolant additives equal???
Old Mar 28, 2005 | 10:07 AM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
I've been doing a little research on coolant additives and the main ones I'm considering are:
- RedLine Water Wetter
- Royal Purple Purple Ice
- 40 Below
- Valvoline Zerex
They all seem to be pretty much on par with each other...just curious if anybody has preference to a particular brand for any reason....
Most likely I'll just pickup whatever one I can find cheapest....I believe they recommend changing it every 10-15K
- Joel
Old Apr 10, 2005 | 05:41 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
yeah whats the story on 40 below? i saw some at autozone, and it was like 25 bucks for a small can of it, is it worth it?
Old Apr 10, 2005 | 05:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They're intended to be used with straight water in racing engines. I don't know if I'd want to use an additive on on the street. If you're having cooling problems, you'd be better off correcting whatever's wrong.
Old Apr 10, 2005 | 08:09 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I added Water Wetter to my radiator before the last flush (last week) and saw no noticeable change in cooling. That said, I made sure there was a bottle in the radiator after I flushed it last week. Nothing is too good for my car.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
