Hypertech Fan Switch Install Connector
Old Apr 17, 2005 | 05:37 PM
88IROCDT's Avatar
Car: 1988 IROC Convertible
Transmission: 5 Speed
Axle/Gears: G92/3.45
Went to install my hypertech cool fan switch today.
Got underneath the car and noticed that there is no connector on
the car to attach to the one that comes with the hypertech switch.
Is the female end of this connector something that hypertech
forgot to send with the switch or do I have to get one myself and splice it into the the wire going into the old switch? If so, where could I get one?
Old Apr 17, 2005 | 08:37 PM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Transmission: WC T5 / 700R4
Axle/Gears: 10 bolt 3.73
the connector on your car should plug in were the blue one is on the new switch.just ditch the connector you got with the new one.
Old Apr 17, 2005 | 11:16 PM
88IROCDT's Avatar
The blue(actually gray) part that connects to the switch itself is the same,however; it looks like the heat has gotten to is some so I want to replace it.
Old Apr 26, 2005 | 04:45 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Then cut the black connector off the new wire, and then cut the melted connector off the old wire. Then just connect them together. voila
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
toronto formula
Nov 10, 2015 06:17 AM
NBrehm
Aug 25, 2015 11:49 PM
TA8487
Aug 16, 2015 12:21 PM
