Will this thermostat fit on my GTA '89 ?
Old May 20, 2005 | 01:25 PM
GTA89's Avatar
Car: Pontiac Trans Am GTA
Engine: 5.7 350
Transmission: TH700R
Hello,
last time when i was in the USA,
i purchased this for less..
Please check this thermostat out.
His name is :
Superstat 195 F Heavy Duty Thermostat
part # 59359
see picture below..
I live in the Netherlands,
temperature is here approx. 5-20 celcius....
winter : -10 - 5 celcius
summer : 5 - 38 celcius
so tell me, i must replace the old one,
because its rusted, old etc..
I want to install it into my GTA 5.7 1989 engine
Hope will get your answer soon.
Old May 20, 2005 | 05:00 PM
carfixxer's Avatar
Car: 87 GN & 87 T
Engine: 3.8 V6
Transmission: 200r4
I looked up 89 GTA 5.7 and these are the numbers for Stant that I get. How long ago did you purchase this?
The best I can suggest is to remove your old one and match them up side by side to make sure they are the same.
Stant 45359 See image and details for this item
OE Temperature; Superstat; Use w/7 Lbs + Pressure; Verify Pressure Cap Operating
Lifetime Replacement Warranty
Stant 13359 See image and details for this item
OE Temperature; Reverse Poppet; Use w/7 Lbs.+ Pressure; Verify Pressure Cap Operating; Or {13309}
2 Year Limited Warranty
Stant 13009 See image and details for this item
Economy; Use w/7 Lbs.+ Pressure; Verify Pressure Cap Operating
Old May 21, 2005 | 04:49 PM
GTA89's Avatar
Engine: 5.7 350
Hi,
thanks for help,
i bought it last year, november 2004 when i was on holiday
in phoenix, arizona.
they do like same.
but i don't want overheat the car,
so i must know it, will this really fit correctly ?
Old May 21, 2005 | 05:02 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
That looks the same as your factory 195 temp thermostat. If shipping and availablity were such large problems for you, I would recommend a 180º thermostat.
Old May 21, 2005 | 05:07 PM
GTA89's Avatar
Engine: 5.7 350
no not at all..
they are cheap.
but,
i ve a F-Body.NL First Meeting Day in Holland at 5th june 2005
and shipping tooks 12 days... :-) little too long..
thanks.
Old May 22, 2005 | 04:39 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
with those kind of temps, a 195F stat will be just fine.
if i remember right, 38C is like 85F,... i don't even want to know what -10C is,... other than WAY too cold for me.
Street Lethal
Apr 30, 2019 12:14 PM
The_Phoenix
Feb 4, 2016 07:10 AM
krisner89
Oct 10, 2015 06:03 AM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
