New coolant leak - long trip coming up - need advice please
Old Jun 20, 2005 | 10:38 AM
onebluemcm's Avatar
From: Ithaca, NY - 10 sq mi surrounded by reality - I'm SOL!
Car: '89 IROC-Z
Engine: 305 TPI in stock trim
Transmission: T-5 w/ Hurst B/P shifter
Hey all-
I posted this in the TPI section because I have a TPI car - I typically hate same posts in different sections but this is quickly going to get urgent for me - have a long trip next weekend and and already a very busy week to deal with. Finding time to do a repair is going to be hard.......
Got to work this am with steam from under the hood. Have a coolant leak - coolant is pooling on top where the lower intake plenum meets the head.
First - causes - what could it be - please say intake gasket leak, not head leak. By the way, engine oil is normal - no sign of water there.
Second - any estimates on time for repair? I have to travel next weekend, so it would probably be an after-work evening job this week.
My specific questions for the repair are does the entire intake have to come apart or can it come off the heads as a unit ? Any special tools I need? And parts - just a lower intake gasket set? I'm assuming the lower intake has water ways in it......
Really appreciate any help or advice on this problem. I'm a relatively competant mechanic with descent tooling at home, but nothing special tool wise here. I feel like I can doo the job, but would like to know what I'd be getting into. Thanks all,
Kevin
Old Jun 20, 2005 | 11:10 AM
onebluemcm's Avatar
Car: '89 IROC-Z
Ok - I got time to do a search - sounds likt TPIs are intake gasket leakers.
I need advice on dealing with the distributor removal/installation so I don't mess up the timing - haven't done that on this car yet.
Also, still would like an estimate on time for repair - can I do this in an evening, even if it is a late one?
Oh, also - should I use gasket sealer in addition to just the gaskets??
Kevin
Old Jun 20, 2005 | 02:45 PM
CaysE's Avatar
Mark the cap, rotor, and housing to line up with any part of your engine (or put a mark on the firewall), and you can just pull out the distributor. You may need a long flathead (about as long as the dist shaft) to realign the oil pump gear if the dist doesn't go back in the right way.
I've never worked with a TPI, so I don't know what else needs to be done to remove the intake, but that will cover dizzy removal and installation.
I would check the t-stat housing and upper hose, as well, just in case.
eightsixseven
Dec 16, 2024 01:50 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
mustangman65_79
Sep 1, 2015 03:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
